Old 12-22-2014, 11:21 AM
Originally Posted by IHCadetCollector View Post
Yes, they should have a coulter. As for the rust, take a wire wheel to the plowface till it shines otherwise you won't be doing any plowing with that. When your done wire wheeling it grease it up to keep it from rusting do this after every time you use it too.
Wire wheel won't shine that thing up. Grinder with a flap disk, or even a grinding wheel (don't get carried away if you use a actual grinding disk). Then, use it, USE IT, USE IT!! Best way to shine a plow..... USE! See if you can find a farmer that will let you go run it in his field. Take a scraper and don't let dirt build up on the moldboard. Scrape it off as often as possible and eventually, it will shine. Then like the IHCadetCollector said, keep it oiled so it doesn't rust up again.
Old 12-22-2014, 11:39 AM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Couldn't hurt to at least knock the rust off it with a wheel or grinder but as you pointed out it will never get as good as it would if you use it in the field. If used enough it should look like a mirror.
I lost track of what I own a long time ago!
Flap disc seems to be doing the best, with brown Roloc's coming in second. I really want to clean it up some first then plow. Guy had maybe 10 plows, and only one with a coulter. There's 40+acres next to me with a hole in the fence so yeah I'll be plowing.
Old 12-22-2014, 01:02 PM
Steve149's Avatar
Steve149 Steve149 is offline
near as I can tell with a bit of photoshop trickery it looks to measure 12"
Old 01-16-2015, 09:16 AM
If anyone heard a Tim "The Toolman" Taylor style 'ARRR ARR ARRR' last nite about dark it was me turning dirt in the garden. The 129 pulled it fine, I got a lot of learnin and adjusting to do.
It is a 10" plow, I marked the shop floor on the sides of the plow and measured the distance between. Plowing does polish it more than anything.
Old 01-27-2015, 09:54 PM
Scored a coulter from a member here. Now my plow is complete.
Old 01-27-2015, 09:56 PM
Bought a cutivator also. Was pretty rough. Made three new standards from 3/4" round rod(practiced some blacksmithing, heating to red hot and pounding the ends flat and then adding a curve) bought 6 new tines and welded up a couple cracks in the frames. Made wheel stands also(but not in the pic) by welding 1/2" clevis pins to 3/4" round rod-I had part of one wheel stand to copy.
