Old 02-15-2015, 10:59 PM
Originally Posted by fleetlines View Post
That cover is just under 19 " long. I don't have anything to measure against but I'm thinking a 102 or something else had a shorter cover and that got used. Of course it could have been cut. I don't know.
It would be a job changing the tunnel because it's part of the whole frame. Sure it could be done, but highly unlikely.
By the way, good looking FEL
Old 02-16-2015, 12:24 AM
fleetlines's Avatar
fleetlines fleetlines is offline
Originally Posted by mjsoldcub View Post
you did good with the local guy...as i said before; i just use key stock for the trunnion repair...i have seen the plates from extreme...im not sure if theyre made of steal with a higher carbon content or a.r, but key stock is just a couple bucks and a little more wear resistant (harder)...either way it is a nice tractor, that loader is sweet...im sure she'll be a good work horse!!!
Thanks guys. I'm thrilled to even have a little FEL here. For snow of course but we were hit with a flood and there's piles of creek bed in my yard I still need to get cleaned up. It will be a work out for it. If it can handle that I'd like to go over it this fall. If it can't I may go over it sooner.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 02-16-2015, 01:31 AM
wm-webb's Avatar
wm-webb wm-webb is offline
Maybe it is metamorphosing into a SGT?
Old 02-16-2015, 12:35 PM
mattoney mattoney is offline
Dumb question: Has anyone tried to cut the cover off around the dash tower and make their own removable cover, similar to what a wide frame has?
1966 Cub Cadet 122
1968 John Deere 110
1968 Cub Cadet 104
1971 Cub Cadet 107
1975 Cub Cadet 1650
2 Brinly Plows, Brinly Disk, Brinly Grader Blade, Brinly Box Blade, 3-42" decks, 1-50" deck, a Sears 3 pt hitch I bought for $20, a couple dual wheel adapters, CW36 & QA36 snow throwers, 1A tiller, and a partridge in a pear tree.
Old 02-16-2015, 12:50 PM
Ive never done it but I will if I ever get another nf, makes everything so much easier to work on.
Pap's 100
Restored 108
1211 Dual Stick
1050
