Old 02-14-2015, 10:56 AM
fleetlines's Avatar
fleetlines fleetlines is offline
Default Exposed Trunion on 123
This gap exposing the trunion don't seem right to me. This has the Johnson Loader on it. Is it right or could it be a PO moved it back to make more room to get in and out?
I'll need to do the same repair on a 1650. I've never done one. I'd like to make it foot control while I'm at it since it is a loader.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 02-14-2015, 11:09 AM
cubby102's Avatar
cubby102 cubby102 is offline
It looks like maybe the po has cut the frame. The hydro adjustment hole seems to line up with the fenders/seat pan location
Old 02-14-2015, 11:16 AM
Terry C's Avatar
Terry C Terry C is offline
I think he shortened the tunnel cover. If he moved the fenders and seat back then the angle of the fenders to the footrests would look strange and they look correct, unless he moved the footrest back also.
Terry
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-14-2015, 11:34 AM
I agree with the other guys, it looks to me like the tunnel has been cut off.
For the life of me I don't understand why.
I agree with the others, I think the cover was cut. On the plus side it looks like they cut it straight so it shouldn't be to hard to fix.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-14-2015, 12:09 PM
fleetlines's Avatar
I can not see anything that looks different than a factory cut. No burs, straight and true. I don't see where anything was moved either. I'm more concerned with the trunnion. I'll have to see others to figure out what is up with the gap. Maybe a shorter cover was put on.
Old 02-14-2015, 08:05 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
Maybe the cover they put on was shorter because somebody cut it.
I lost track of what I own a long time ago!
Old 02-14-2015, 09:10 PM
I don't think the tunnel cover was cut. I think the fender pan is set back further than it should be.
Old 02-14-2015, 09:42 PM
Merk Merk is offline
Same here
Project Uncle Dick
Cub Cadet 70
Old 02-14-2015, 09:54 PM
I agree,the tires will be closer to the front edge of the fenders,and if you measure the front edge of the pan to the dash tower i can check mine and see if it is the same.
Up to 534 and counting...
