#21
Just trying to have all the bases covered. Plus its something I should have in the future if I wont to keep these things running. Plus after looking at the invoice I would think there should be no problems with the carb. I HOPE
#22
One bank is running richer than the other. I suspect low compression on one side. I suggested testing compression.
#23
If it seems to be running well now, I'd shut the hood and not worry about it. You might look at the plugs again and see if the coloring is now the same side/side. |
#24
The carb runs both cylinders, so the only way one side can run differently from the other if there is a problem with it. It won't just "get better" by adjusting the carb. |
#25
I can see you wanting to recommend another big money repair here on a 30-35 year old engine. ![]() You do it your way and I'll do it mine. Thanks. |
#26
Yep, you do it your way and I'll do it mine. Meanwhile I'll try to save this guys motor for him while you tell him to just ignore it. Who's really helping?
#27
What are you going to tell him if he spends the $$$ for a compression gauge and and finds has low readings? Spend more $$$$ for a rebuild on a 30-35 year old engine? ![]() Or what if he pulls the plugs and now, since the engine appears to be running much better, the coloring is closer to correct and consistent, side/side? Apparently he fixed something when he put the new gas line on because the engine is running better. If it turns out this be the case, then it's time to ignore his former issue. That is what I said, not what you said I said. |
#28
Could have a bad head gasket on one side. OP can probably borrow a comp tester from an auto supply store. I didn't read that J-mech is suggesting that the OP spend big bucks, maybe I missed something? I seem to recall that he usually recommends doing a re-power rather than spend a lot of $$$ on these old engines. Carry on.
#29
-Ryan
#30
That's what I'm betting. Cheap fix.
