Old 05-03-2016, 11:40 PM
how exactly do you go about hooking up a relay to kill the mag? my engine has a rectifier on it.
I'm no good at making diagrams on a PC, so I'll explain it. It's easy....
5 terminals on a relay. They are 85, 86, 30, 87, 87A.
85/86 are the control portion. One is power and the other ground. Doesn't matter which. Hook one to ground, the other to the powered ign circuit that used to run to the coil (originally).
30 is the "in" portion of the switch circuit. Ground this terminal.
87/87A are the "out" portion. 87 is normally open, 87A is normally closed. Hook the wire to the Mag to 87A.
Terminal 87 will not be used.
When you turn the ign on, it will open the ground contact to the mag and it will run. When you shut it off, it will close the contact to the ground and kill it. Easy peezy.
Old 05-03-2016, 11:48 PM
that makes sense, thanks
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-03-2016, 11:54 PM
Terry C's Avatar
Terry C Terry C is offline
Since I replaced the hour meter with an oil pressure guage, I used the wire
that powered the meter to power the solenoid on the carb
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-03-2016, 11:55 PM
Does it keep time as good as the meter did?
Old 05-03-2016, 11:57 PM
Terry C's Avatar
No it's stuck on 40 o'clock.
Terry
3225
