Old 11-22-2020, 04:21 PM
ironman's Avatar
ironman ironman is offline
[QUOTE=CubbyRI;502581]OK this is the kind of confusion. I am holding in my hand a regulator that has four terminals. L, Batt, F (field), and one on the bottom that is Armature.
In that case he bought the wrong regulator and will have to return it.
I can't argue if he has a v/r that is stamped "armature".
Old 11-22-2020, 05:41 PM
CubbyRI CubbyRI is offline
OK Guys, to clear it up what I am doing, I bought a 100 to restore. Since then, I have picked up a couple more tractors a 70 and a 123 IIRC, and even more parts (two hydro rears, a couple SG's) .
HOW-EVER as General Burkhalter used to say, this particular issue is with the SG I posted above and the regulator I posted above, installed on an antique engine. yes, I fitted a Cub cadet CCW SG to an antique engine in my boat. Works wonderful.
BUT now I have to hook up the Regulator and discovered it is not straight forward.
The SG I have is listed for a later 12x tractor.
The regulator I have has terminals L-Bat-F and one unmarked on the bottom!
Will it work, or not?
Model 100 Dec 2020 - Running condition, has snow plow!
Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one
Model 100 Feb 2019 apart for total frame-off / sandblast etc resto
Model 70 Sep 2020 needs total resto and an engine, or for parts
Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts.
two spare hydro rears
"in for a penny, in for a pound!"
Old 11-23-2020, 10:57 AM
ironman's Avatar
In my humble opinion, it will work if you wire it as described for the 70/100 drawing above.
However, assuming that your boat does not have a stee/metal frame where you will mount the v/r, you will need a grounding strap from the v/r case to the motor or neg terminal of the battery.
Old 11-23-2020, 11:50 AM
thanks iron
yep. I recall reading somewhere that the VR must have a good ground, so I ran a tinned marine wire from the VR mounting ear right to the SG bracket, using tinned marine crimp loops.
As far as the tractor project, I dont think I have a wiring harness for the tractor and might make one, although I bet if I click the sponsors here I can find aftermarket harnesses.
BTW, what RPM do the SGs start making a decent charge? This engine runs at 500rpm with a 10" flywheel and I made a double pulley that's IIRC 3.5" so thats 1500rpm at the generator. If you can tell me what the CC tractor rpm has to be to see the ammeter move decently, I can convert that.
Old 11-23-2020, 01:15 PM
1500 rpm is barely above idle speed for a Ciub Cadet with the Kohler engine.
Old 11-23-2020, 01:20 PM
Gotta get a bigger pulley, but not a bigger boat...
Old 11-23-2020, 01:24 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
I kinda wanna see some pics of that boat engine
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 11-23-2020, 01:34 PM
And if your real lucky it might put out 1 amp that low of an rpm, possibly not.
Remember, this is a generator not an alternator, alt's charge a lot more at 1500
than a generator.
In a kohler engine application IIRR, the motor pulley is maybe 5-6" and the motor pulley is about 2-3"
So at rated 3600 motor rpm's where it charges a full 15 Amp, the generator is turning prolly near 5000 rpm's
Now this is just approximation, because I haven't measured the actual size of the pulley's I don't have.
Old 11-23-2020, 01:52 PM
Thats 1500 generator rpm... engine 500rpm. engine pulley is 10" generator pulley is about 3.5". I can put a smaller pulley on the SG tho. So, if have to, I will. But gotta get the VR installed and see the charging amps first.
How many amps do you guys see with these anyway?
Old 11-23-2020, 02:53 PM
A Cub Cadet S/G at full throttle (3600 RPM's), puts out 15 Amps.
