Old 06-25-2012, 10:25 PM
Nice work, Conner! Thanks for the pics and update.
Old 06-25-2012, 10:43 PM
mrcubcadet's Avatar
Thanks, Allen!
Got the frame power washed, and decided to go ahead an start priming with an extra Valspar primer can I had...Will flip it over and do the other side tomorrow morning.
Turning out really nice, without any runs.
-105___ Tiller
Old 06-25-2012, 11:04 PM
Anytime Conner! Your frame is looking good!
Old 06-26-2012, 10:40 AM
Conner your doing a great job!
Old 06-26-2012, 12:20 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
looks good little man,,,, remember on sanding primer, only sand what you want the paint to stick to.....
Doug
Original , 100 , 125 , 582
Old 06-26-2012, 01:43 PM
Darrell Darrell is offline
I seen you where you are going to have your hydro check valves rebuilt , i would strongly suggest getting the automatic valves instead. They are ALOT more convenient , especially once your flapper that holds them down breaks. They may seem pricey , but well worth it.
Go Here .... http://onlycubcadets.com/
The link ain't workin' , go to Technical Library , Tractors , Hydro Check Valves , and there is a supplier.
Old 06-26-2012, 10:42 PM
mrcubcadet's Avatar
Thanks guys! ...This is turning out much nicer than I thought it would!
Going to try and get the transmission/rear end done, and ready to prime tomorrow. Then prime it, and finish priming the frame Thursday morning...Before the 90-100 degree temperature!
I am planning on shooting the frame and trans/rear end with paint this weekend sometime...Can't wait to try out the new gravity feed gun!
-105___ Tiller
Old 06-26-2012, 11:16 PM
Looks great mrcubcadet! Be sure to wear a great respirator if you are painting with hardener. It'll look awesome when you're done.
Old 06-27-2012, 12:44 PM
mrcubcadet's Avatar
Thanks, bud!
I will make sure to if I do..But I don't believe I'm going to use hardener on the frame, and rear end.
-105___ Tiller
Old 06-27-2012, 01:00 PM
mrcubcadet's Avatar
Spent a couple hours this morning working on the trans/rear end..
Took the rear cover off, dumped out all the green Hy-Tran, and replaced the gasket..Then took the hydro pump off, and replaced the old thin cork gasket. Sealed everything back up, and then installed the rebuilt relief valves. This thing shouldn't have any leaks, now!
-105___ Tiller
