Old 08-10-2014, 05:38 PM
NE149's Avatar
NE149 NE149 is offline
Solid copy. You're talking Fastenal the bolt/parts company right?
What condition do you need the motor in to ship it? It still has a bit of oil inside. What parts do I need to re-attach? I've got the carburetor off, etc...
Old 08-10-2014, 05:43 PM
No oil, and unless you want me to do more than the reciprocating assembly, I just need block, head, crank, rod (that way I can put a bearing insert in) cam, valve train and rear bearing plate. Then you finish assembly and break it in. All I do is take care of the "internal" stuff. (It will be returned with a full gasket set, obviously minus the bearing plate gaskets, head, and main seal because they will already be installed.)
Old 08-10-2014, 05:48 PM
NE149's Avatar
So I need to take all of the gears out of the inside you're saying? You'll have to forgive me with all the parts stuff since I'm new to figuring this out...
You need the whole casing of the motor, the cast iron part, you need the aluminum head, you need the crankshaft, and....Ugh. Head is hurting.
Do you basically need the motor put back together, piston inside, rod bolted back in, all of that?
Old 08-10-2014, 05:55 PM
If you have it apart, I suppose you can leave it that way. I don't care about the balance gears, (if it has them) or the piston, they will just go in the scrap pile.
Old 08-10-2014, 06:51 PM
NE149's Avatar
I pulled the side cover off where the valves sit to see inside..
The exhaust side has black buildup inside that compartment, and the carb side has black build up in the chamber that the valve travels through to get to the top...
Old 08-10-2014, 07:36 PM
yeeter yeeter is offline
I shipped a complete 782 motor from MA to Iowa with fastenal for $50
