Old 08-06-2014, 10:21 PM
NE149's Avatar
NE149 NE149 is offline
Default Got a 149 with problems.
Howdy all, I bought a 149 for fairly cheap from a neighbor for a project. Slowly I am fixing minute things. it runs, however I was told it burns oil. Also it blows some white smoke at start and stutters at high rpms. Gearheads at work mentioned rings or head gasket. i was wondering if a rebuild kit would fix my problem? Or I could there be a bigger or smaller Iissue?
Thanks
Mike
Old 08-06-2014, 10:31 PM
does the smoke smell like oil or old gas?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-06-2014, 10:52 PM
NE149's Avatar
Hmm... smells oily to me, the guy ran some with it around the yard. I could drain the tank there isn't much in there. Doesn't oily smoke usually blow blueish?
Old 08-06-2014, 10:58 PM
generally oil burns blue, thats why i asked about the smell as old nasty gas burns a whiteish color. it breaking up on the top end of the throttle could also be from bad gas or the carb need rebuilt/adjusted
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-07-2014, 01:36 AM
NE149's Avatar
To me it seems like it could be more white than anything, I will drain the tank tomorrow and run some fresh fuel in it and see how it does then.
Old 08-07-2014, 11:25 PM
NE149's Avatar
Fresh fuel did not help, still had smoke. I also drained the oil, it was nasty, and has some streaks of something in it, maybe it was gas?
Old 08-09-2014, 08:50 PM
NE149's Avatar
Pulled the piston today, no rings were cracked or anything like that... what else can I look for? I'm going to grab a micrometer from work and mic the cylinder...
Anyone have the link to the manual that gives acceptable tolerances?
Old 08-09-2014, 09:06 PM
It is in the Technical Library Section..... K Series Service Manual
Old 08-09-2014, 09:18 PM
NE149's Avatar
Thank you! Lots of little areas to explore here!
Old 08-10-2014, 12:54 AM
I'm guessing this is the first motor you've ever taken apart.
Well, since you pulled it down, just start piling up your pennies to rebuild it. No need to go mic'n the bore. Just go find a shop and have them bore it. No sense in going that far and not doing it right. The shop will tell you how much it needs bored. No need to measure it.
No, before you ask, honing it and slapping a set of rings in it isn't a rebuild, and it's a waste of time. Do it right, the K series are cheap motors to rebuild. Done right they last, oh, around 25-40 years depending on they're use. (About 1500-2000hrs or more if you take care of them)
