#41
Ok a update. I cut some grass a week ago it ran pretty good then started to act up again. So I did what many posters suggested & removed the carb & cleaned it. I used a method that I had read here by using pine sol. Now this is the first time I got into a carb. I did not find any dirt, grim, or anything that looked dirty to me but I did the full clean anyways. I bought a rebuild kit & put things back together. So now when the engine runs a idle its perfect but if you bump the throttle up just a little it runs a full rpms. Not only that it increases rpms to the point it sounds like its going to blow up. Checked all the linkage an everything seems to be working as it should. This weekend I was able to play with the throttle to the point where I could mow but the throttle was just a bump above idle & the rpms where at about what used to be full throttle.
I should also add that I set all the adjusting screws to where the manual says to start.
#44
Sounds like the governor is not functioning. Download the Kohler manual and adjust the governor to carb linkage.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
