#41
Congrats on the fix Tim
Nice to turn a negative into a positive and relatively easy... and cheap
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#42
Good deal Tim!
![]() Just keep that white stuff north of the Mason-Dixon Line!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
#43
I sprayed it down in with a straw and put a pretty good amount in and let it sit for a few minutes, once I hooked the battery up and it started working I flipped it over to drain the extra fluid out and put it back together. Hopefully it keeps working but if not it will get replaced by an oil pressure guage.
#44
i finally got some free time to work on the 1811, the hour meter repair didnt last and it stopped working again so i replaced it with an oil pressure gauge and was happy to see that it carries 55lbs at an idle and about 65lbs at wot when warmed up. the po must have had some extra lighting and had a ton of extra wires running all over the place so once i got it all sorted out i have working lights except for one headlight thats burned out. the cat 0 lift went on easy enough and tomorrow i will make lift links so it will be complete, i also tubed the front tires. also on the list for tomorrow is to mount the snow plow and bolt on the winter tires that are already loaded and have the chains on. i had a fun day working on it and it was really nice to take it for the first ride all in one peice.
#45
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#46
Thats gonna look nice when you paint it.
Up to 534 and counting... I give up updating my profile! |
#47
Hopefully you get to see it in person next year at PA plow days.
#48
Sounds like a fun time!! Cub stuff is fun!
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#49
Hurry up cause I want to see what a new one looked like. Well with you doing the work it probably will look better that it did new
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
#50
believe me i want to tear it apart right now and get painting it but i figure its best to run it for the winter to work any bugs out before i make it pretty.
