Old 10-11-2015, 07:26 PM
Default 1811 project
I scored this today for $200, I bought it from a friend that sells cub parts and has over 100 cubs on his property. He said he's never tried to start it but that he thought the engine was locked up, when I got it home and started to tear into it I found that the reason it seemed locked up was because the the flywheel area was filled with acorns. After removing a huge nest and a ton of acorns it turns over just fine and feels like it has alot of compression, a quick check down the oil fill revealed a fully intact governor. Tomorrow its going to work with me to get pressure washed, I'm going to change the oil and do a compression test and try to start it. Does anybody have the info for pinning the governor? The sign was free .
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-11-2015, 07:30 PM
twoton twoton is offline
Good deal for 200.
Old 10-11-2015, 07:31 PM
Tim,
The 1811 is a great tractor,keep us updated on your progress
Up to 534 and counting...
Here's some pics after I was done tearing into it, the orange liquid came out of the fuel tank. The rearend is incredibly clean and doesn't have any crud on it so I'm hoping it doesn't leak.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-11-2015, 07:34 PM
It seems to be in overall good shape and unmolested, it even has these stickers on the wheels that I've never seen before.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-11-2015, 07:45 PM
Nice score Tim.
Old 10-11-2015, 08:16 PM
Originally Posted by twoton View Post
Good deal for 200.
best part of the deal is the fact that he has about 10 more out there and if anything on this one is bad i can just take the part out and exchange it free of cost. the guy i buy from is cool like that.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-11-2015, 08:17 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Great find! Looks to be in nice original condition. Even still has the pressure decals on the rims. Did the seller have a mower deck that would work with it? How many hours, and does the meter work? You should hear it ticking like a wind-up clock when the key is on. Those Mags are stout when tuned properly. Good luck!
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 10-11-2015, 08:29 PM
the seller has about 100 decks but i have a few also so i bought it without one, the hour meter shows 1000 but im not sure if it works since ive yet to install a battery.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-11-2015, 08:53 PM
EricR's Avatar
EricR EricR is offline
Very nice Tim!!!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
