Old 07-01-2018, 07:46 PM
Originally Posted by gretschwhtfalcon View Post
Nothing at all to disconnect on that rear end? Surprising. I can't quite picture how it would separate so easily. So you also concur that this can be done without a hoist? What would worry me infinitely more than taking the old one out is damaging something putting the new one in. It just seems like it has to be one of those "looks easier than it actually is" jobs.
Then there's also the problem of shipping the core. A concern here, as I've expressed before, is whether or not the core would even be accepted if indeed the broken rod damaged it inside.
The drivehub on the engine is a slip fit on the driveshaft. It's the larger piece on the left. The driveshaft has a 1/4" pin that fits the slot.
Old 07-01-2018, 08:13 PM
gretschwhtfalcon gretschwhtfalcon is offline
So that pin has to be removed before the engine is free to lift out?
Old 07-01-2018, 08:14 PM
No, it should slip out. ( if the slot is worn crooked, a slight turn may be necessary but no big deal )
I'll get a picture of used parts. I made the parts in the picture but they are already packed up
Old 07-01-2018, 08:16 PM
Shipping the core to who?? Someone else, or me?? I take care of all that. You need not worry. If you buy from someone else, then I have no idea how they handle it.
As long as I get a motor back and block is salvageable then you get a core credit. Seldom are the blocks damaged beyond repair. Only seen a few that were totally junk. Everything in the engine would have to be junk before I wouldn't refund at least a partial core.
Jon...IF I go with the restore option, which I'm really leaning towards now -especially if I could do this engine swap pretty much by myself, - I'd be buying your engine. I don't want to get involved in researching and talking with other people, checking out their engines, etc. Too much else on my plate right now for that. We would just need to work out a few more details....
Old 07-01-2018, 08:29 PM
That's fine. Still awaiting a call from you.
Oh, pm me your complete address so I can get the shipping quote.
Old 07-01-2018, 08:30 PM
here you go. These parts are exactly what yours has
Old 07-01-2018, 08:34 PM
SLS327 SLS327 is offline
Any reason why you wouldn't install the pin in shaft? Thats a pia to install!
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 07-01-2018, 08:40 PM
Just thinking, that its hard to press that shaft in.
Steven
Old 07-01-2018, 08:48 PM
When I make driveshafts, I do NOT install the pin as the purchaser needs to put on the cooling fan before installing the pin.
One thing I do to make it a bit easier is to make the hole the exact same size as the pin just at the beginning of the hole to make it easier to start straight.
Old 07-01-2018, 09:01 PM
Ah, yes. Havent dug into mine that far yet.
Steven
