Old 06-11-2013, 10:30 AM
seawalkersee seawalkersee is offline
Man...you're gonna love that. I know I would.
SWS
Old 06-11-2013, 11:11 AM
SWS
Same here!
Old 06-11-2013, 06:27 PM
dragoncub dragoncub is offline
Hey guys I was wanting to put a diesel in my 782. I have a couple of kubota d600's I wanted the dimensions of the motor mount brackets so it would sit in the 782 just like the original one did and it would make it a lot more easy to get it all hooked up.
Old 06-11-2013, 07:01 PM
Originally Posted by Mr.Goffena View Post
Some thing about this just seems right. Plus the drive line is the right length. Sooo how much longer is a super than a GT? I have been told its 6 inches or just move the fenders back until the front holes in the fender meet the rear holes in the frame.
So, you are stretching it too? ..... I don't know about how you want to do it. Here is a frame for a 1872. $124
Old 06-11-2013, 09:42 PM
Mr.Goffena's Avatar
Mr.Goffena Mr.Goffena is offline
Originally the radiator and engine had there very own mount then the whole assembly got set into the tractor. At least thats how I think it was done.
Old 06-11-2013, 09:45 PM
Mr.Goffena's Avatar
I saw that frame for sale but its just too far away. Besides I have a junk 1250 that I can cut the frame rails off of I just need to know how much longer they need to be. I have read that the super frames are dilled for a GT as well.
Old 06-27-2013, 10:40 PM
Mr.Goffena's Avatar
Well after a bunch of measuring I finally did it i can't go back now.
Old 06-27-2013, 10:48 PM
Thanks for the pic and update! Keep up the good work.
Old 07-07-2013, 09:59 PM
Mr.Goffena's Avatar
Got some work done on the 692 the last couple of days. I got the rear end built. I put on the cast axle tubes and disk brake axles off the 1250. I also installed the ported hydro from the 1250. I put on the tall tires that I got from work they are 12x14x26. They are alittle wide but when I get the ag tires they will work. I also got the 4 bolt hubs installed that came off the back of the turf cart. I had to cut some spacers for the inside then I used washers to get the proper endplay.
Old 07-07-2013, 10:10 PM
Thanks for updating us, and the pics.
