Old 11-22-2013, 10:57 AM
Don't worry about diverting the thread in this situation no body will have an issue with it.
Mac
That's right! You post about Major and Schultz all you want.
Old 11-22-2013, 11:51 AM
Originally Posted by sawdustdad View Post
Thanks for all the kind words and thoughts. We are leaving for the vet in a little while with Major. He hasn't eaten in at least 4 days and is very weak. It's time.
With any luck, the tractors, boats, and work will be distraction enough. I'm really worried about his companion, Schultz. Here they are together about 5 years ago...They've been inseparable since they were puppies. Major has been the "alpha male" with "Sergeant Shultz" his loyal partner in crime.
Didn't mean to divert this thread so much. It's just that Major has been such a constant companion with me in the shop...I guess Shultz, normally snoozing away while Major is "helping" me, will start to get all the attention.
Shultz will be lost for awhile without Major, as will you and your family. When we put Gunner down, Ruger his son was looking for him for days. Time heales his wounds I suspect.
Good luck
Old 11-22-2013, 02:38 PM
sawdustdad's Avatar
Got the hydro back in the tractor last night, with the new trunnion set up. There is virtually no slack in the linkage now, though there is a little slop in the control plates where they fit on their respective shafts. next step is to add a filter, fill with hytran and spin the unit up with a drill to check operation. The lift valve spool seems stiff, so I might have to pull that out and replace or repair it. I do have a spare if I need it.
Major went peacefully in my arms earlier today. Schultz hasn't figured it out yet.
Old 11-22-2013, 02:40 PM
Thoughts and prayers!
Old 11-22-2013, 06:18 PM
Trunnion rebuild looks good
Did you put a washer in front of the control plate behind the snap ring? I don't recall the thickness, but I remember doing it on my 123 way back. It takes out the slop, so to speak.
Hopefully someone with a better memory than me will chime in with the correct thickness.
Thoughts and prayers for you and you family
Old 11-22-2013, 06:25 PM
"Major went peacefully in my arms earlier today. Schultz hasn't figured it out yet."
We get that you are trying to deal with the loss of a loved one. Take some time off from the Cub stuff. We are here for you when you come back. RIP Major.
Holler if you want to talk.
Mac
Old 11-22-2013, 07:22 PM
Sugarmaker's Avatar
Default dogs and cubs
sawdustdad,
Been through this too.
Thinking about you and your dogs.
Hope your day is good.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-22-2013, 09:58 PM
Sorry to hear about Major.
Old 11-22-2013, 10:30 PM
sawdustdad's Avatar
Got the pair of motor mount rails from Lew (Darkminion_17) yesterday, and prepped them for the cradle mod. Mounted them to the oil pan and will tack them prior to removing them and welding them up. Also, finished closing up the hydro with the suction pipe and filter. Filled the rear end with HyTran.
We're headed down to the river for a few days. Next update will be sometime next week.
Wife spent the evening looking at labra-doodles on line...that didn't take long.
Old 11-26-2013, 09:51 PM
sawdustdad's Avatar
Off from work this week, and the boat is all winterized and put to bed for the winter. (still have some projects there, but home for the rest of this week).
I hooked a drill up to the hydro and spun it up (clockwise from the rear shaft looking forward, so that's the same as counter-clockwise from the driveshaft perspective) . It didn't do anything until I removed the release valves and added some hytran. Nothing in the manual tells you to vent the unit or fill it with oil so I am wondering if this is normal? Any thoughts? Once I got oil in it, put the valves back in it, I managed to get it to move the tractor forwards and backwards. I think it's going to work? made some funny sounds, but I suspect this is due to air still in the system? I don't know.
Welded up the iso mount rails and installed the driveshaft and engine. Should have it running in a couple weeks to at least fully test the hydro. Need to rebuild the carb, mount fuel tank, coil, condenser, etc. to get it running. Really not that far away now.
