#8681
Great pictures of the Cubs on Firewood duty guys
#8682
Thanks, Sam and Diz!!
Today, I moved the mower decks down to the barn for winter. Also cleaned up in front of the shed with the Super and cleaned up some sticks and whatnot and killed it with fire and adult beverages! ![]() ![]()
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
#8683
Nice work Shrewcub
Great pictures |
#8684
#8685
Finished putting a hydro fan on the 149 and decided to change the oil, then when filling the oil I hear something running on the ground, take a look and the aluminum oil pan has cracked around the drain plug
![]() So my oil change went from 10 minutes to 6 hours pulling the engine and swapping a cast iron oil pan, decided to pull the grenade gears while I was in there, they were pretty loose. It did make greasing the steering box easy though.
#8686
Ran out this morning , between the rain drops to get the Rebuilt Hydro Release valves back in. Buzzed Tug around the yard all all RPMs and speeds, reverse too.. Valves are all nice and dry. While some Covers were off I greased and oiled some of the linkage.
Thanks MACHTECH
If I can't fix it , it must not be broken |
#8687
Hydrostatic oil & filter change on the FIL's 2182 SGT today as well as my 2155. Even with the workshop heated up by the coal stoker and the oil warm it takes quite a while to ease all those quarts of oil into that skinny little fill hole on both tractors.
I don't think I'll be doing anything that requires patience the rest of the day! I was hoping to change the engine oil & filters as well but ran out of time so I'll probably mess with that tonight since I left the stoker running. |
#8688
#8689
Used the FEL again today, time to dig up the septic tank covers! It did better than I expected, the dirt was pretty hard with a lot of rocks, didn't even spin much.
#8690
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart 882- 50c Mower Deck 2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade Case 646 FEL Case 446 |
