Old 04-15-2011, 11:47 PM
jpianalto jpianalto is offline
Default center button missing off front pto???
My pto seems to be working but is slipping when I hook it up to the 44" mower deck. it will work if it's spinning only the center spindle on the deck but not all three... now i bought a kit to rebuild it and i've read up on it, watched a couple of youtube videos about it and i'm ready to go tomorrow... HOWEVER:
i just noticed that it looks as if my thrust button and my wear button has been replaced with the following...
a center post connected to the clutch shaft assembly... resting between the arm that holds that center post / punch is actually a plastic washer
can this be correct???
Old 04-16-2011, 06:46 AM
Your thrust button should look like this.
This picture is during assembly, but you can see the parts and where they go.
Notice the throw-out levers where they contact the thrust button, yours will need replaced.
The wear button looks like this.
This one is worn, but you get the idea.
Hope this helps a little.
Old 04-16-2011, 10:17 AM
it certainly does... i've seen complete pto assemblies as well as seen assemblies done on youtube but since mine would engage and disengage before i bought the kit, i wondered if cub experimented with something different... i guess whoever got this one going before i bought it, was very good at "rigging" things up to work in different ways... he actually built a steam engine from scratch to scale... it was very impressive!
Old 04-16-2011, 10:24 AM
Yea, people come up with some impressive solutions sometimes.
The PTO on one of mine had a similar (fix). It worked.
But once i put it back original it works so much nicer
