Old 04-16-2011, 03:49 PM
Default Starting the assembly of my 128 K301
I received my governor gear and cross shaft yesterday from Chris Westfall. This is what I have been waiting for. Well waiting for the $$ to get it ordered..LOL. I took a few pics and will post them thru my progress in the assembly. If someone see's something I have done wrong or could do different please feel free to speak up. Better to catch it now than later.
Governor and cross shaft:
Got the cam installed and marked the timing mark with some white paint:
Old 04-16-2011, 03:57 PM
The cam end play should fall between .005/.020
We have .007 well within spec
Marked the Crankshaft timing mark:
Aligning the Camshaft and crankshaft timing marks. Took me 2 or 3 times to get it right, LOL:
Got the bearing plate installed and setting up to check Crankshaft end play:
End play should be between .003/.020. I ended up having to install 3 gasket shims:
Finally obtained a .010 reading:
Old 04-16-2011, 04:38 PM
westofb's Avatar
westofb westofb is offline
Great pics of the rebuild! Looks like your doing great, keep up the good work!
Jeff
Brookfield, MO
________________
Old 04-16-2011, 05:29 PM
Thanks a lot Jeff, I enjoy doing stuff like that. Been awhile since I have tinkered with a motor.
Old 04-16-2011, 06:03 PM
DWayne awesome pics! Your well on your way now. Looking forward to more awesome pics of your progress!
Old 04-16-2011, 07:11 PM
Great pics, DWayne! Looking forward to your updates!
Old 04-16-2011, 07:43 PM
william1041200's Avatar
Im surprised greatly that no one spoke up about the plastic gov gear. Go for the cast iron gear if you can find it!
Old 04-16-2011, 08:08 PM
I figure the original plastic gear lasted 37 years of weekly use, this should do fine. It will see some use, but not like it used too. What I have to find is a cast iron deep sump oil pan. I don't like the aluminum one. It has some wear at one of the frame bolt holes.
Old 04-16-2011, 08:25 PM
hey DX3. Guess What I have? I would trade for a CI flat pan!
Old 04-16-2011, 11:30 PM
Mooner's Avatar
Mooner Mooner is offline
DWayne, looks great! Thanks for sharing your photos of the progress.
