Trying to install a IH wide frame spring assist on a 129 but the spring
is rubbing against the trans . Anyone with a pic or diagram to ensure I'm putting this on correctly . I have been known to dummy up once in awhile .
![]() here's a pic from a different thread on here... NOT my tractor or pic. Just a fyi.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs. |
Thanks ..saw that , but it doesn't show the rock shaft bolt up
Got a pic of how you have it installed?
I will get a pic tomorrow, but once you put it in there you will see there is only one way to bolt it up. Really no guessing to it at all.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
That's what I thought DX3 ....I don't like the way it is rubbing against the hydro case
This might help
I have a hi res copy if you need it.
That is much better than my picture can show.
Thanks Lew ...at work now , but pretty sure that's how I had it ...
I'll check here out whenI get home |
I was reading the PDF and noticed that it referred to the lift handle. Obviously they are talking about the manual lift handle. Does a spring assist do any good on a hydro lift model?
1811 Hydro "Failing to prepare is preparing to fail".
