I am trying to remove the 3pt hitch from my 1450 so that I can get it put in my 1250. I have taken the fenders and back wheels off, lift bar taken off. Now comes the part that is troubling me, what is the easiest way to get the lift lever shaft out? I sprayed the heck out of it with PB Blaster, then used a hammer to beat the shaft to the frame, can I use a pipe wrench to try to twist it out? How does everyone else get these out?
Jim Bridgewater, KD0FJO Osage, IA 1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow |
If you are referring to the 5/8" shaft that holds the cast rockshaft on up at the top between the frame rails, I bought a 2' length of 1/2" bar and used that and a small sledge hammer to pound out the shaft. When you put the bar into your 1250 use a healthy does of anti-seize on it.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Remember that when you bang on a steel shaft the end will get a lot bigger than the original shaft was. Ask me how I know this is true? (rebuilding a top loader tranny). If you have to you can cut the shaft at one end and then pull the cast piece out and then have a better shot at it to heat and push the shaft out.
1811 Hydro "Failing to prepare is preparing to fail".
