Old 05-09-2011, 10:27 PM
eddy622611 eddy622611 is offline
Default 1641 Engine surges
I mowed 2 hours with my son's 1641 on sunday. The tractor ran well at w.o.t. but when I would turn off the pto and cut the throttle to half the engine would pop and start to surge and would continue unless I pushed it back to wide open. Shut the tractor off and let cool a while. Then restart and it will sit and idle smooth. We just bought this tractor, so we don't know any of its history. Thanks, eddy622611
Old 05-15-2011, 08:33 PM
I had a chance to run the tractor again to day. The surging seamed worse than I wrote about before, other than w.o.t. it is hard to get the tractor to run smooth. Its acts like it is going to stall and then it comes back to life again and again. Thanks, eddy622611
Old 05-15-2011, 09:03 PM
I looked up your carb online, it does not have the electric fuel metering rod so I don't think that is the issue like it was with my 2185. The next thing I can think of is possibly your coil is going bad, or one side of it is going bad. I know someone here had an issue with the coil on their twin engine causing about the same issues that you are giving. Maybe they will see this and chime in.
Old 05-15-2011, 09:15 PM
Thanks DX3. I just did a search on a briggs site and some of the results where a dirty pilot jet. I was going to order a carb kit and filter. eddy622611
Old 05-15-2011, 09:34 PM
Probably a wise thing to do, and very well might be the issue. I was just thinking of the rod not working right like mine had done, not some junk inside, LOL.
Old 05-16-2011, 05:58 AM
Well, atleast I'll be able to rule out a dirty pilot jet. When I adjusted the valves I had the plugs out and they where light brown. So I'm thinking more of a fuel issue than electrical,but I've been wrong before. Thanks, eddy622611
