Old 05-15-2011, 12:41 AM
Brim Reaper's Avatar
Brim Reaper Brim Reaper is offline
Default finished building my sub soiler/ middle buster
Friday I went to my local scrap yard to buy steel for my projects and found some really big box scrape rippers/ scarifiers with the tooth and got them cheap.I took the rippers and some other steel I had laying around and built a really cool cat "o" sub soiler. I was out playing around with it before the welds cooled off. I used it in some areas in my field where the water will stand a couple inches deep after a heavy rain. It works better than expected , goes about 12" deep and the old 17HP kohler seems to kick it up a notch on the power and chug along effertlessly.
Old 05-15-2011, 06:47 AM
Nice find on the parts Brim Reaper
Nice fab work on the sub soiler also
Old 05-15-2011, 09:17 AM
Nice work! Is the there any adjustment in it or is it in a fixed position? Thanks for the pics too!
Old 05-15-2011, 09:33 AM
red211's Avatar
red211 red211 is offline
How about a pic of it in the ground, even a little action video maybe?! Looks great, think it could pull two?
Old 05-15-2011, 10:53 AM
The adjustment is in the cat "0" hitch linkage. To be honest I have it all adjusted to where the tool point is about 3" clearing the ground in the up position and still ripping 12" deep. To go any deeper it will take a cat "1" tractor with the larger range of motion to the hitch. I thought about making two and mounting them on the tool bar I built but I didn't know if the tractor would pull it . That brings me to another question, I want to either buy a brinly plow or make a double 10" bottom plow setup with the two plows I took off a scrap horse drawn deal. Will my 782 hydro pull it? I noticed with my other implements that this may be tricky with the hydro . What do most of you use to pull at the plow day meetings? Thanks Steve
Old 05-15-2011, 12:19 PM
Steve That's how I thought you had it set up but didn't know it could go 12" deep!
Double bottom plow would be nice and your 782 would pull it but I wouldn't use larger then 10" plows. A disc plow might be easier to plow with. And with this red clay we have around here doesn't make it easy to plow. Looking forward to seeing what you come up with.
Old 05-15-2011, 03:50 PM
Excellent job, Steve! I like it!
