Old 05-22-2011, 09:49 AM
Default 1450 Adventure
Was mowing the lawn yesterday with my 1450. All was going along real good and then I noticed a slight miss in the engine. The motor kept going for another minute and I noticed it again. Then for about another 3 seconds, then the motor died, like someone turned the key off. Well, it was a bit warm out in the sun and I needed something to calm my nerves. To the refrig for a cold one. After getting calmed down, went back into the yard where the 1450 died. Started looking at what was the problem Couldn't get the motor to even roll over. So, I started with the Neutral Switch, that seemed OK. Looked at the PTO Switch, that seemed OK. What in the hell is going on here. So I took a screw driver out, and jumped the Starter Solenoid, The motor barely wanted to turn over. Lifted the seat and found one of my ground cables with a broken end (at battery). So, I put an new end on and no improvement. So...now it is time to get the Van over to the tractor with the Jumper Cables. Jumper-ed the tractor and it started right up...hmmmm
So, I was noticing that the Amp Gauge was in the middle. I revved up the motor and no change in the Amp Gauge. So, now I am thinking, with the battery that low, I should be charging like mad. I reach around to the V/R and jiggle the wire connector. Lo & behold, it is now charging, way into the charge position. I jiggle the connector some more and notice the charging goes in and out. Ah ha.....dirty or loose connection at the V/R. Clean the connector up and now it remains charging. Mowed another hour and still was charging slowly building the battery back.
NOW....the conclusion to this adventure, the motor died from running low to the point where it wouldn't provide enough voltage for the HV Ignition Coil. This was in turn due to the V/R not working.
I don't always look at the Amp Gauge to see if there is a charge going on, but from now on I will.
Old 05-22-2011, 10:39 AM
R Bedell
Nice trouble shooting.
Glad you got it back up and running
Old 05-22-2011, 10:48 AM
Roland I think it knew you were working to hard and needed a cold one. Glad you got it figured out. Some good problem sloving steps too!
Old 05-22-2011, 12:04 PM
Glad you got your 1450 going, Roland!
Old 05-22-2011, 10:15 PM
Mooner's Avatar
Mooner Mooner is offline
Wow, that was an adventure. I try to keep an eye on my ammeter most of the time. Glad to hear you got it figured out. You deserve another cold one.
Old 05-22-2011, 11:35 PM
william1041200's Avatar
I got a 12 pack of cold cold ones for ya if you can figure mine out. I just gave up and charge it with 120 v charger when it needs it.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 05-24-2011, 01:25 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
Mine has done something similar, other than it charges fine when the PTO is off, but as soon as the tiller is turned on, it won't charge. I ran it for two hours the other night and it started popping and missing. Turning the tiller off eliminated that.
I hooked it up to the trickle charger overnight, and all is well, but I need to trouble shoot this problem. PTO on equals no charge.
Thanks for sharing your fix.
