Does anyone know if a 12HP K301AQS is the same as a M12AQS. Tring to find out what the differences are but no luck.
Thanks in advance Mario |
The engine from the 1320 should be a vertical shaft, so that won't work. The one from 2130 would probably work with some mounting and drive shaft mods.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
your motor is a 12hp kohler magnum horizontal shaft here is a link to some of the specs of it, http://www.smallenginewarehouse.com/...asp?PN=7752236
