I installed mowing deck under my 1450 yesterday. I noticed that left side of deck barely came off ground with lift up and right side is lot higher even with adjustment in lowest position. I believe that someone has misinstalled "rocking" part on left side to shaft. Could someone post pictures under tunnel cover? So I can see if it is misinstalled(mirrored).
Tero |
Tero:
A possible problem here could be that the LH spirol pin is broken allowing that side to drop down. The Spirol Pins are used on each end of item #1 to secure each arm to the shaft.
Hi,
Picture shows that item no 2 is installed mirrored. This is the problem then I have to flip it around. Thank you for help. Tero |
![]() Tero: You are right, and that image is from the Cub Cadet Lookup site. But, that Spirol Pin I was talking about would apply the same. Those Spirol Pins can be had from a well stocked Hardware Store or Supplier. For example, they can be had from here.... Spirol Pin If I recall correctly, the dimensions of the pin are: 1/4" Diameter by 1-1/2" Long (6.35mm x 38 mm)
