Old 05-23-2011, 10:00 PM
Guitar Guy Guitar Guy is offline
Default Fuel filter question
My QL 1000 has a replacement tank with no filter. I'm looking at the style shown in the link below, since I have very little room to work with.
It's listed as a 75 micron filter. I've found the same style in a 150 micron. Does anyone know which would work best for my 10HP Kohler?
http://tinyurl.com/3dsuv49
Thx, Josh P
Old 05-23-2011, 11:07 PM
gazoriginal gazoriginal is offline
that fuel filter is only 1/4". if im not mistaken, i think you need a 5/16" filter. i think either micron filter will be fine, as long as it has a fuel filter on it. :hope that helps.
Old 05-23-2011, 11:28 PM
Thanks, I suppose I'll have to disconnect the line and measure it before I order a handful of filters. The PO re-plumbed everything with the replacement tank, so I'm not sure if it's the same size line as OEM or not. He did install a petcock, but no filter.
JP
Old 05-24-2011, 05:51 AM
An important thing to consider, is that the Fuel Filter needs to be the "gravity feed" type.
