Old 05-24-2011, 02:24 PM
jmroy's Avatar
jmroy jmroy is offline
Default Welding Thin Metal
I need to do the shifter repair to the transaxle I just took out of my parts tractor. I have a stick welder and an oxy acetylene torch set. Which would be best for this job? I've welded with both before but I'm worried about burning a hole in the shifter cup since it is kind of thin. I was thinking maybe a 6013 rod? I've used it before and found it really doesn't penetrate too deep which might be perfect for this job. I could use the oxy acetylene but I'm partial to the stick welder.
Web Developer - Need a website? Contact me.
Old 05-24-2011, 03:19 PM
Southtowns27's Avatar
Southtowns27 Southtowns27 is offline
If you absolutely have to use the stick, use some very small (1/16") 6013 and only make very short beads so the material has some time to cool off. Running the 6013 on AC will also cause it to penetrate less.
A better option is to find a buddy with a MIG and give him a case of beer to weld it for you.
Old 05-24-2011, 10:13 PM
Can't beat the oxy/ace on thin metal.
a 000 tip will weld tin cans no problem, been doing it since '62
Old 05-25-2011, 12:31 AM
shouldwe's Avatar
shouldwe shouldwe is offline
i would use oxy/ace, if you use stick i would go small and 7018. but i think the best bet is take it to any garage and have them weld it, the probably wont charge you.
Have you driven a cub lately
