Old 05-30-2011, 09:45 AM
nott one nott one is offline
Default Pto
the drive belt broke while mowing replaced the belt now the pto will not stay engaged
Old 05-30-2011, 09:49 AM
To help you which model is this?
Old 05-30-2011, 09:54 AM
Sounds like the bearing froze up, broke the belt and will not stay engaged due to the bearing being locked up. Have you taken the pto apart and checked the bearing?
I merged your two threads into one.
Old 05-30-2011, 09:55 AM
It is a 2544
Old 05-30-2011, 10:00 AM
The PTO will work without the belt. Deck spindles feel ok
Old 05-30-2011, 10:07 AM
So you have not checked the pto other then turning it on? Your going to have to take the pto apart and check it. Engaging it without hte belt on it doesn't tell me anything. The belt creates load on the pto assembly.
Old 05-30-2011, 11:39 AM
i did a pto on a older model cant remember (old age) how to hold to motor to loosen the bolt with out an impact thanks for your help
