Old 05-30-2011, 04:21 PM
terkaa's Avatar
terkaa terkaa is offline
Default Thread on oil drain plug?
Hi,
It seems my 1450 was previously owned by some very strong guy. First carb bowl had been overtightened to the point of cracking carb body. Next spark plug also had broken threads(helicoil is under way). And now I noticed that oil drain plug has been glued into its place with plastic padding. So I would like to know what is original thread for this? So I can order correct repair helicoil and tool.
Tero
Old 05-30-2011, 04:38 PM
Here is what the Parts Manual states..........
Old 05-30-2011, 08:33 PM
william1041200's Avatar
that is 3/8-18 NPT Pipe thread. You can get helicoils for this.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 05-30-2011, 10:00 PM
TEET's Avatar
TEET TEET is offline
Check your local Napa...they usually have a good selection of helicoils...good luck
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 05-31-2011, 06:53 AM
Jeff:
Do they have NAPA stores in Finland...???
Old 05-31-2011, 08:20 AM
TEET's Avatar
Sorry Tero...there are a handful of international members here, so I apologize for assuming you live in the U.S. and would have a Napa auto parts store near by. So.... I would think you could possibly have a DIFFERENT auto parts store that carries this type of thing within reasonable distance. Good luck
CCC 1211
71
127
102
122
1962 Original
