Old 05-30-2011, 09:04 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default 1250 problems
Well, I HAD my 1250 running and driving this morning. I shut it off, turned the key back and pto switch on to see if I had juice going to the pto. I then got a phone call and had to leave for about 3-4 hrs. Stupid me forgot to turn the key off. Now I can't get it to start. I checked the points and they aren't welded together. Where should I go from here?
On a separate note, I got to looking at the pto and it doesn't look like it is pushed clear on the shaft. How much clearance should there be between the outer ring and engine block?
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 05-30-2011, 09:10 PM
From what I have read, the coil will cook (lack of a better word), if the key is left on and can cause a no start issue. There is a file in the tractor library that shows how to check the coil and make sure if it is in or out of spec.
Coil Link:
http://www.onlycubcadets.net/forum/showthread.php?t=11
Old 05-30-2011, 09:35 PM
Makes sense, as the coil was very warm when I brushed my hand across it. Will have to dig out the multi meter and check it out sometime this week.
Old 05-31-2011, 05:55 AM
You may have also "cooked" the PTO switch. You may want to check that too.
