Old 06-02-2011, 09:15 PM
Soaper Soaper is offline
Default 126 running issues
didnt want to post this in my thread... so made new one for thoughts.
the video sucks. but to break it down.
im at 1/2 - 3/4 throttle running and its smoking every few seconds.
then u can see where i go full throttle. and it does it also but not so much...
u can tell a lil better with the exhaust towards black car.
i did notice it has a bad head gasket... replacing that tommorow.
and the air filter is letting unmetered air in... which im fixing tommorow
any insight.
thanks.
Old 06-03-2011, 12:53 AM
any insight.
thanks.
Once you decarbon the head make sure it's flat (there's a guide in the tractor tech section) check your plug I use autolite 216's in my cubs. Check your oil level to make sure it's not to high. And always check your timing using the static timing method or with a timming light. Once you do those lets see if it's still smoking.
Old 06-03-2011, 12:56 AM
ya saw on a kids site Matt cub page or so that shows how to do the head.
take it i can pick up the spark plug at any auto parts store?
i havent replaced it yet.
also need to replace the plug wire.
Old 06-03-2011, 01:23 AM
Yeah any auto parts store should have the autolite 216. They are like $2 each. Get your plug wire there as well. Take your old one tho.
Old 06-03-2011, 09:29 PM
AMCJavelin74 AMCJavelin74 is offline
I prefer Champions (if they're made in USA. Check the box, some are made here and others overseas. Wix and Purolator filters are that was as well. Just a FYI.), but if the Champs are foregin, I normally ask for an AC Delco. Anything 2 cycle or Japanese I'll use NGK.
Everyone has their own preferences, and so long as your plug of choice works well, run with it! Ditto with a spark plug wire and such.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 06-03-2011, 09:35 PM
Several people on OCC have had problems using champion plugs. That's the reason I use the Autolites never a problem and they are priced right. I do agree use what you like it's your money not mine so spend it as you see fit.
