Old 06-03-2011, 06:26 AM
horseplay horseplay is offline
Default 1862 Hydrostat
Thank you for allowing me to join this group. I own a 1862 I purchased new. It has been a wonderful tractor. Lately the hydro was not centered and when you push on the brake it would not go back to center. I adjusted lever centering rod length and centered the lever. But as before when you push down brake it does not go back to center. I think something might be wore in linkage. I looked in my owners manual and it has no info on this adjustment. Thanks for your help.
Old 06-03-2011, 06:58 AM
Horseplay:
First, welcome to our Forum...........
You will need a Service Manual for your 1862. It is manual 772-4166. You can obtain one from our Sponsor - Binder Books listed above.
Old 06-03-2011, 08:04 PM
aagitch's Avatar
aagitch aagitch is offline
There should be a separate linkage adjustment that will make it go back to center/neutral when you push the brake.
Adrian
2072 (789513)
