if off color talk offends you then hit the back button!!!! LOL seriously, i have just recently acquired a 1982 allis chalmers 716. it has a broken rod and also it has the balance gears. my question/comment/what have ya! if a motor came with the BG's do you HAVE to put them back in? i mean, they were designed to have them YET only one of the kohler motors i have has them (69 14hp economy). i realize that it reduces the vibration, but i'm not going to cut grass with it, just use it as a bigger tractor. i really don't won't them in there because on more than one occasion, i have heard of them letting go and doing ALOT of damage. everyone please give me thoughts and opinions. thanks, jeff i will post pics later
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716 Jeff |
Their designed intent was to reduce vibrations on Kohler singles, but the extent of vibration dampening goes almost unnoticed...at least to me, and I've run and heavily used tractor with, and without them. I usually remove them when I rebuild a block only because they have been known to grenade and destroy other internal engine components.
So my vote is.... if your in there, take them out... if you dont have any in there now, leave it that way ![]() Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
If the BG's are in there get them out of there! Nothing good will come out of leaving them in there!
I have a way with words myself! I agree with the rest, leave the balance gears on the bench! They were a horrible engineering idea.
104 to 127 conversion with dual 6x12s, hydraulics snow/dirt plow 1200 Quietline 44" mower QA-36 snow thrower |
I just got to that point in disassembly with one of my engines that has them. Is there any way to/should i remove the shafts they're mounted in? It looks like I can drive or press them out but that would leave two holes in the block?
Web Developer - Need a website? Contact me. |
The shafts will be fine. If I am not mistaken, they are machined in the block, no way to remove them.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
here is a picture. jeff
Nice AC, Jeff!
you can never go wrong with an Allis Chalmers or Simplicity! great machines. almost like them more then cubs
