Had to remove 2 steering wheels from 2 CC 122's. Purchase the steering wheel puller you see on Ebay. Place puller on the first wheel it came off in about 5 Min. real Easy. Great I said. Put it on second one ended up breaking the tool( to much torqe). Sent email to James asking what it would cost for the two pieces I distroyed. He said to send him check to cover shipping and he would send the two parts at no charge(NOW THATS CUSTOMER SERVICE,THANK YOU). While I was waiting I hit the steering shaft nut area with PB Blaster for 5 Days. Got the parts and tried again only tighting with a wrench by hand would not move, over the last 3 days I would just keep hitting it with PB Blaster and repeat with wrench using more force each day. Well today I did it again and finally it went POP Loudly. I figued I broke it. But all ok. I just cann't believe how well this tool and PB Blaster works together. If I did this the other way with the bolt and upward pressue with knees I would still be pounding away. On to next project steering rebuild.
Lesson I learn is that before I try and remove anything I will soak it in PB Blaster
,1 Ariens 934 Hydro with cyclone rake |
Glad you got the steering wheels off. My 122 will be getting the same treatment here soon.
A little trick I learned is to mix Isopropyl alcohol and transmission fluid, then spray the part that is stuck. It takes 1/2 the ft. lbs. of torque to break it free compared to PB blaster and 1/3 the torque over WD40. Only problem is you need to mix it just prior to using it as the alcohol evaporates very quickly. This technique and mixture was proven during a study at some well known university. Hope this can save some grief and save some steering wheels.
CaptMax
CC 1964 Model 70 Serial# 78905 Creeper gears, Round fenders, Spring assist. CC 1965 Model 102 Serial# 127109 Creeper gears, 3 point, Carlisle AG's, headlights, and a cigarette lighter. 42" Blade, Brinley plow, 42" mower deck, 1A tiller, QA36 snow thrower |
If you work on these tractors alot this tool is worth the money. The one thing I did learn about this is you can use to much force just take it slow and easy. I also purchased a clutch compression tool off ebay that has save me alot of of time and trouble. Building up my shop one tool at a time.
Will have to try that mix you talked about to see how it works
[QUOTE=CaptMax;78451]A little trick I learned is to mix Isopropyl alcohol and transmission fluid,
transmission fluid or cleaner? just a clarification... thanks!
147 w/ 42" deck w/ 3pt hitch all in memory of my grandpa's 124 |
Nope, never a need to.
CaptMax
[QUOTE=jpianalto;78520]
ATF, fluid. CaptMax
