Old 06-16-2011, 12:06 PM
MFP8055 MFP8055 is offline
Default Drive line vibration
I finished an engine rebuild on my 1210 and now have the tractor in service again. New iso mounts are in place, but I still have a lot of vibration campared to my 1650. I took a close look at the drive shaft connection to the engine and saw that there's about an 1/8" misalignment that make the shaft wobble. I don't recall any adjustments on the coupling. Any suggestions other than just rotating the rag joint to another position?
IH 1650, CC 1210, 1610 and Bolens 1257
Old 06-16-2011, 12:50 PM
How does the bushing look?
Old 06-17-2011, 08:25 AM
Good question. The fiber disks (rag joint) look real good. That's where the connection to the engine is made. On my 1650 with a K341, I recall an actual bushing where the drive shaft contacted the engine. Not so on the 1210 with an M series engine. Maybe it's a design issue?
Old 06-17-2011, 08:46 AM
Nope, not a design issue...if there isn't a bushing there, there should be. See #8 inside of #7 and #13 in this drawing...
It's likely still there but has worn out and the inner part separated from the outer part. Here's what they look like:
CC charges more than $20 each for these things, so if you have multiple tractors, it makes sense to order them directly from the manufacturer for nearly 10x less.
Old 06-17-2011, 08:52 AM
Attachment 12443
There's one inside #13 as well, but that one is not replaceable on my 2072. I replaced both on my 2072. They are a wearable item that needs replacing from time to time.
Matt you've got let me know who the manufacturer is!
Old 06-17-2011, 09:02 AM
aagitch's Avatar
aagitch aagitch is offline
http://www.triangleoshkosh.com/eng/p.../ball-bushings
HE 1410P bronze
Adrian
2072 (789513)
Old 06-17-2011, 09:24 AM
Thank you!
Old 06-17-2011, 09:48 AM
The one inside #13 is replaceable, I just did one last night. The bushing is just pressed into the plate, it comes out very easily using a hammer and socket as a driver.
Old 06-17-2011, 09:56 AM
I should also mention that if you order from the company, there is a $30 minimum purchase, which comes out to 12 of these. I bought 20 just to make sure I wouldn't run out for awhile.
Old 06-21-2011, 09:01 AM
I'm familiar with the component from rebuilding my 1650. It never dawned on me that the bushing was missing. It wasn't there when I took it apart and the previous owner must have tossed it. I need to do some additional work on the tractor so the bushing will be installed shortly. Thanks all.
