Old 06-21-2011, 09:07 AM
MFP8055 MFP8055 is offline
Default Trunion shaft seal replacement
I'm finally getting around to replacing the leaky trunion shaft seal on my 1210. It looks like I'll have to drop the rear end/hydro assembly out of the frame to do this. Has anyone extracted the seal from the hydro unit without taking it apart? It's a small seal so I'll probably have to make some kind of a puller. I've asked this before, but thought I'd get some fresh advice before I start in on it.
IH 1650, CC 1210, 1610 and Bolens 1257
Old 06-21-2011, 09:19 AM
If it's the left side trunion seal, you have no choice but to disassemble the rearend. If it's the right side one you can pry it out with a screwdriver.
Old 06-21-2011, 02:49 PM
Also there is another trick that sometimes works:
Knock a hole in the seal with an ice pick, or better, drill one, then insert a sheetmetal screw.
Then pry out the seal taking care to use something to pry on giving you the needed leverage.
Old 06-22-2011, 10:54 AM
Fortunately, it's the right side. I'll try to pry it out, or as suggested previously, use a slide hammer.
