Old 06-21-2011, 02:51 PM
dcubfan dcubfan is offline
Default 149 deck and mule drive to a 1282
hey all,
Will a deck and undercarriage fit/swap from a 149 to a 1282?
thanks
darren
Old 06-21-2011, 03:04 PM
If it is a 44" or 50" deck it should swap with no problems. You also have to remember a 149 uses a 3/8" PTO belt with the decks above and the 1282 will use a 5/8" PTO belt. You would have to buy the correct center pulley for the deck for it to work. Hopefully there will be some others chime in with some different ideas maybe.
Old 06-21-2011, 07:10 PM
aagitch's Avatar
aagitch aagitch is offline
You'll probably have to change your mule drive pulleys too.
Adrian
2072 (789513)
Old 06-21-2011, 07:40 PM
OH, good catch Adrian, I didn't even think of the mule drive pulleys.
