Old 06-24-2011, 08:22 PM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Default 44A Zerk Fitting
Would anyone know what the dimension are or a part number of the zerk (grease) fitting on the spindles of a 44A mowing deck?
I just finished cutting grass and notice I was missing one.
Old 06-24-2011, 08:39 PM
The grease zerk is part of the Bearing Assembly and there is no separate part number for just the zerk. You may have to examine the zerk(s) from the other bearings and go to a Ag Supply House or Ag Dealer and match up the best you can.
Old 06-25-2011, 09:50 AM
Mike1450's Avatar
Thanks R.B. Thats what I thought since I did not find any info on it. But I just had to ask knowing that someone may have had the same issue at one time.
Old 06-25-2011, 02:48 PM
Mike1450's Avatar
If anyone ever has to replace a Zerk Fitting here are the sizes
The original fitting on the spindle that came from the factory is 1/4 -28
The stern replacement spindle have a 6mm - 1 size
Both were found at my local Autozone
