I am in need of the dimensions for the lift rod spacer on my 3-point hitch. This is item # 711-3073
This is the only part holding me up from installing my tiller and hitch. If anyone has the measurements I would greatly appreciate it. Thanks! CaptMax
CC 1964 Model 70 Serial# 78905 Creeper gears, Round fenders, Spring assist. CC 1965 Model 102 Serial# 127109 Creeper gears, 3 point, Carlisle AG's, headlights, and a cigarette lighter. 42" Blade, Brinley plow, 42" mower deck, 1A tiller, QA36 snow thrower |
![]() Ok, If anyone has a good picture of this part can you please post it? ![]() I'm sure I can fabricate one if I know what it is supposed to look like. CaptMax
Let me see if I can help you out Captain. I know for a fact the OD is going to be 3/4". I will try to get you the ID. I know the bolt that I put into the lift rockshaft threads was a 3/8" bolt, but I will double check.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
![]() CaptMax
The ID is 1/2". An 11/32 socket I had fit perfectly into the bushing. It measured .509 or 1/2". I lost the correct bolt to use in the bushing and am using a standard bolt till I can get another. There is definitely just a bit of slop with a 3/8" bolt thru the bushing.
11/32" socket ![]() Socket measurement: ![]() Wrong Bolt ![]() ![]() 3/4" OD
Thanks DX3, I will get one turned on a mill my friend has and finish installing it.
This is how it looks at the moment, I also just finished restoring my snow plow so that is why it is mounted this time of year. I sure love my Cub!!! CaptMax
That is one sharp looking 102. You need to make you a sleeve hitch for that trailer ball. It's useless with the bracket mounted. I have the same problem too.
If I had a 102 that looked that great I'd be showing off more pics of it!
I would but I am too embarrassed that it's missing a fender reflector. I have one of those showing up real soon thanks to a member here on the forum. How about a picture of my new wheel weights and rubber I just got mounted? ![]() CaptMax
