Old 07-01-2011, 06:51 PM
CubDieselFan's Avatar
Default 1572 Trans-fluid Leak
I finally got a chance to trouble-shoot my fluid leak on my 1572 and need some advice. I got lucky on this, I thought it was the cork gasket as old as this tractor is. Looking at the hydro from the operator seat view, the right valve on the top is spitting fluid. Is this as simple as replacing the valve or is there something else causing it to spit fluid. Any help would be appreciated. Thanks, Greg.
Old 07-01-2011, 07:02 PM
Swap the valves and if the same valve is spitting fluid then the valve needs replaced. If the same position spits fluid, you have something else going on.
Old 07-01-2011, 08:03 PM
I just swapped them the spitting followed the valve. Thanks for the help. Would just go ahead and change them both? Thanks again, Greg.
Old 07-01-2011, 09:25 PM
I would, just a good preventative maintenance thing to do. Roland has an address around here for a heck of a price on brand new ones. I'll see if I can find it.
Old 07-01-2011, 09:27 PM
Here you go:
http://www.onlycubcadets.net/forum/showthread.php?t=3
Old 07-01-2011, 10:19 PM
Thanks, I will call them in the morning and see what the price is. Patton acres has them for 117.00 each. Thanks, Greg.
Old 07-07-2011, 03:26 PM
ChrisA ChrisA is offline
Default Valves
Is it possible to take these valves apart and clean them? Or to flush them with carb cleaner or such? $100 for a pair of valves sounds expensive.
Old 07-07-2011, 03:33 PM
A $100.00 for a pair is CHEAP. Most places want a $100.00 plus, for EACH.
Old 07-07-2011, 05:15 PM
You've also got to look at how long of a life span they have.
Old 07-07-2011, 07:50 PM
I got mine ordered today from L J Fluid power. They were $57.02 each plus shipping. $156.00 at the dealer. There is a guy on ebay that rebuilds them, but that is about 45.00 each with shipping. They are on back order, so I should have them in a couple of weeks. I will let everyone know how it goes.
