Old 07-01-2011, 11:54 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Default Rollguard?
Im wondering if anyone has made a roolguard for the Ih cub cadet. Mainly for a wideframe if so how you went about mounting it?
Old 07-02-2011, 09:16 AM
gcbailey's Avatar
gcbailey gcbailey is offline
there was a factory ROPS for the wide frames... I've saw bits and pieces of one, but not a picture of one mounted... something I'd like to see. It looks like it slants foward toward the hood from what I can tell, but I may be wrong.
Gary
Old 07-02-2011, 10:40 AM
jlampe94's Avatar
Thanks for the replies, they did make one im pretty sure, bolted down in front of the footrests on the frame and leaned back a lil but that was more or less just a shade canopy. Im lookn to see if anyone has made something like thats on a bigger tractor. Mounting its the problem im up against.
Old 07-02-2011, 11:28 AM
gcbailey's Avatar
Originally Posted by Wild Bill View Post
AFAIK, there has never been a ROPS set up for a Cub Cadet GT.
Gary: There was actually a 'sun shade', that IH sold during the QL run. It came off of the frame just in front of the foot rests, angled back as it went up, and then went over the top of the operator. The frame was white, with a yellow top, and white 'fringes'.
Bill, in Ken Updike's book "original farmall cub and cub cadet" on page 103 there is an engine shot of an 800 and this is the sentence quote: "The left view of this model 800 shows the front mounting of the option tractor roll over protection structure (ROPS) that IH offered. The ROPS attachment is very hard to find.
Here's a pic too...
Gary
Old 07-02-2011, 09:28 PM
Merk Merk is offline
This was found Cub Cadet parts look up:
http://www.cubcadet.com/webapp/wcs/s...A/040103300039
It's called a Protective Canopy.
There is a set of rear axle bracket assembly (item 8 and 9) to help prevent roll over (front to back).
Old 07-02-2011, 10:53 PM
Here is a picture of the Protective Canopy:
Old 07-03-2011, 03:05 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Curious as to where you wish to have the ROPS bar located on the tractor. Do you want it in front of you leaning back towards the rear of the tractor OR just behind the center of the seat, similar to what larger tractors have? If your looking into the latter option you might try looking at the BX-series of Kubota tractors that are currently out. Not the model that came with the backhoe standard, that was a goofy machine all of its own, but the other sub-compact tractors that had the MFWD axle & the little diesel engine. IIRC many of those BX's had a ROPS hoop with thick plates, 3/8 to 1/2" thick, on the bottom of the hoop that matched up to the same size plates that were part of a wild & heavy mount bracket that bolted to the frame at the minimum if not the frame, transmission & axle tubes. The fenders were sandwiched in between the plates on some models & others had a cutout for the plates even though the sheetmetal matched up with the plane that both ROPS plates meet on.
Those ROPS hoops were darn solid given their design. Would use an overhead hoist & endless loop strap around the hoop to lift the tractors out of their shipping crates when I used to work at a Bobcat/Kubota dealer.
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 07-03-2011, 09:22 PM
jlampe94's Avatar
Im looking to copy one off a bigger tractor i got the top figured out just im looking for options to mount it, ill take a look at that though. thanks for the replies!
Old 07-07-2011, 09:37 PM
Shaner Shaner is offline
what i would like to know is...what is the point of the rollgaurd if there is no seat belt attachment for the seat.
Old 07-07-2011, 10:31 PM
jlampe94's Avatar
Looks nice, good place to mount some lights, gets flashers up in the air so people on the road can see you better, makes some shade for the operator. I dont plan on rolling my cub any time soon, and in my case i get bored some times and like fabricating-building things!
