Old 07-06-2011, 10:22 AM
msobie64 msobie64 is offline
Default 72 Cub Cadet 128
Hello there,
I'm new to the forum so I would figure I would send out my first post. I found a 72 Cub Cadet 128 w/ 44inch deck in my grandfather's barn (decent shape). I'm thinking about using it to mow my yard (currently down a tractor about 1acre). Its missing the mower belt but looks like the rest is all there. Sure enough she fired up after a little struggle. Looks like its got some rust but nothing that doesn't look more than just surface deep. Any ideas on what I should check over before trying to fire up the PTO/Deck?
thanks,
Mike
Old 07-06-2011, 10:40 AM
mrcubcadet's Avatar
And...
Here is the link to the belt chart, to help you get the right belt.
http://www.onlycubcadets.net/forum/s...ead.php?t=4633
-105___ Tiller
Old 07-06-2011, 11:53 AM
CC1450's Avatar
CC1450 CC1450 is offline
Welcome aboard Mike! I would check that the spindles can be turned by hand and if so grease them up before putting a belt on it. Look at the spindle pulleys and make sure they are not rusted up or have sharp edges that will kill a new belt. Also would be a good idea to look at the underside and make sure there is nothing tangled up in the blades and that everything is intact and tight. When you find a deck missing a belt, you gotta figure it is missing for a reason just to be on the safe side.
-Mark
1978 1450
1976 1450
Old 07-06-2011, 11:54 AM
I would do a good tune up with new points, condenser, oil, and would be worth going thru the carb and cleaning it real good and putting a kit in it. It would be a good idea to instal an inline fuel filter. Make sure it is designed for gravity fed carbs. About any good parts store will have the filter. SAE 30 weight oil. Grease all the zerk fittings. The service manual for you 128 is located in our Garden Tractor library and is worth downloading and printing out. The Owners manual is also there and shows all of the lube points and info you might need.
Check all of the wiring and make sure it hasn't been chewed on and also check to make sure a nest hasn't been made in the blower housing. If the motor can't cool you will run it hot and that isn't good.
By the way, welcome to OCC. We love pics.
Old 07-06-2011, 12:36 PM
Mike
Nothing like a family tractor!
Old 07-06-2011, 03:02 PM
Thanks for all the feedback, I'm pretty sure my grandfather used it to pull a few trailers around his property (2inch ball on the back). I'm not sure if he ever mowed with it, I will be visiting him again this weekend. I'll ask and take a few pictures.
Thanks for the feeback.
Mike
Old 07-06-2011, 04:44 PM
I'm new to this stuff, what is meant by "new points"?
Old 07-06-2011, 05:04 PM
Points are what create spark along with the coil and condenser.
Read these manuals and illustrations to help you understand your Cub better:
http://www.onlycubcadets.net/forum/showthread.php?t=27
Setting the timing and points
http://mgonitzke.net16.net/tools/static_timing.pdf
Service Manual
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
Kohler Service Manual
http://www.kohlerengines.com/onlinec...df/tp_2379.pdf
Operators Manual
http://ccmanuals.info/pdf/1x8-9%20Operator%20Manual.pdf
Old 07-06-2011, 09:34 PM
Thanks for the links DWayne.
Old 07-06-2011, 10:18 PM
Welcome to OCC! Congrats on your 128!
