I'm a cheapskate. Plain and simple. So, without any serious intent to put anyone out of business, specifically our sponsors here at OCC, I'm sharing my substitute for the 1/4" spiral pins listed by Cub Cadet for driveshafts.
I didn't want to just use roll pins in place of spiral pins, they're a risk. So, I inserted (hammered) a 5/32" roll pin into a 1/4" roll pin which virtually doubles the thinkness of the pins which brings their shear strength closer to that of the spiral pin. Also, since both pins will still compress, I had NO trouble at all driving these "modified" pins into the 1/4" holes in my CRS driveshaft. I feel safer using these than a single roll pin. The 5/32" pins retail at $0.23 each, the 1/4" roll pins retail for $0.31 each... The spiral pins retail for as much as $5.00 each. Cheaper, yes... and likely just as strong. Now, if I could just find a suitable substitute for work... ![]() ![]()
Tim Proud to own a 1965 Cub Cadet 122. |
Most people buy them from Master Carr.
You can buy a bag of 25 1/4"x 1 1/2" coiled spirol pins from McMaster carr for about $12. I would not slam one of them larger pins in the coupling that is on the transmission end. Being a cheap skate will cost you in the long run. JUst saying.
![]() Quote:
These aren't larger pins, they're just doubled up. One inside the other, the 1/4" pin is still within the min./max. dimensions given for a 1/4" roll pin. And, they still compress as required for the hole size. I hammered the small one into the other only because it fits snugly and it doesn't greatly increase the outer diameter of the 1/4" pin. The minimum diameter of the 1/4" roll pin is listed at .258, wall thickness is .048. Subtract the wall thickness to find the inside of the 1/4" pin is .162", the exact same measurement as the outside diameter of the 5/32" roll pin which is listed as .167" max to .162" min.
![]() Quote:
To have any thing shipped these days, is a minimum of $8.00 to $10.00 from either UPS or FedEx. I know... I get and pay for parts shipments every day.
For such a small part (physical and monetary wise) it is better to buy locally.
Nope, these are the black ones. I guess I've not been clear enough on this whole thing. I'll try to get a picture of the pin set up and show you guys what I'm doing...
![]() Quote:
The few pennies you think your saving will cast you more in the long run. Hydraulic pumps has pulses and vibrations. Single cylinder motors do vibrate. Quote:
It's your Cub....do as you want. |
Funny you should say that Roland because I am a firm believer in supporting local business. Them coiled/spirol pins are not to be found in my little corner of the world. Hardware stores and tractor stores look at you like you have a third eyeball when you ask for coiled/spirol pins. Most have never heard of them. Nearest Cub dealer is 27 miles away and by the time you put $15 in the tank to make the trip I find it a better option to pay the shipping and have them on my doorstep the next day. And I have 20 to spare.
![]() Quote:
