Old 07-14-2011, 01:05 AM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Default Custom Wideframe Cat. 0 3 point
Well here are some closer up pics of my 3 point i built. Everything except for the ball joints, pins, base part of A-frame and top link were fabricated. Mounts up using all stock holes, no extra holes were drilled in the frame. Lift links going to the bottom 2 arms are made so you can adjust them without disconecting anything just turn it with a wrench and it goes up or down. If you want measurments or anything else feel free to ask. Enjoy!
Old 07-14-2011, 01:07 AM
MOturkE's Avatar
MOturkE MOturkE is offline
SWWwwweeeeeeettt!!!
Proud to own a 1965 Cub Cadet 122.
Old 07-14-2011, 01:08 AM
Very impressive! Way to use the old hat rack!
Old 07-14-2011, 01:10 AM
That is so awesome!
Old 07-14-2011, 09:02 AM
Peruvian Peruvian is offline
Awesome! Not easy to change the Hy-Tran, but awesome!
Old 07-14-2011, 12:15 PM
jlampe94's Avatar
Thanks! Hopefully i dont have to change it again, i did it a while back and again when i put it on, if i do tho its only 2 more bolts pull all the pins and its gone.
Old 07-14-2011, 04:21 PM
Very nice job on your 3pt, darn near factory I must say.
Old 07-15-2011, 09:29 AM
bruce s's Avatar
bruce s bruce s is offline
Jlampe You have done a very nice job on the three point .
Old 07-15-2011, 04:29 PM
rpage83 rpage83 is offline
Very cool. I have been toying with a similar idea for my NF 100. I have the arms and lifting linkage. Just need to figure the lifting rod to the handle, and the brackets for the bottom.
SWEET JOB indeed!
Old 07-16-2011, 06:09 PM
papaglide's Avatar
Man that is soooo impressive! Great job!
WH 417-A
WH B-80
WH 416-8
WH C-165-8
Mike
