HELLO Recently bought a Cub Cadet 129 at a local auction Been doing some tune up work to it ,Oil, Air , Htdro Fluid & filter , cleaned & degreased everything ,ect. Haveing some troubles keeping it running it seems to boog down wene in motion full speed or near it . to the point were it stalls or nearly stalls. If I put direction selector to N the RPM's build back up . Is this a Hydrostst problem or a Ignition / Run problem I put a new silanoid & cond the points look like there brand new unsure of Volt Reg. Looks older ?? ( on flat level ground or up hill ) Thanks for input in advance. I need to get me a good service manual as well any sugestions ?? I will add some pics this weekend Thanks Again !!!!
Also seems to mainly boog down wene PTO is engaged I adjusted the PTO belts in front did'nt seem to help ?? I'm going to try to add a couple pics as well.
welcome to OCC forums!
I would guess your running issues are carb/ fuel delivery related. If you have not done so already, pick up a carb rebuild kit for around 10 bucks or so, and go through it.
![]() -Mark 1978 1450 1976 1450 |
Nice looking 129!
Here is the link for the Kohler service manual:
http://www.onlycubcadets.net/forum/s...ead.php?t=4646 And the Service manual for your 129: http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
![]() Sweet looking 129! |
I installed an inline fuel filter on it , It did'nt have one, that should'nt effect anything should it ? Were would I get a carb rebuild kit on ebay or ?? I bought the tractor an extra wider deck & a snow plow at auction for $ 400.00 I think I did good ??? I actually need it I'v got about 2 acres to maintain & my 12 yr old Craftsman riding mower is dieing , I'm actually glad it's sooo Hot out it is giving me time to get the Cub running perfectly before I need to mow again .
Our sponsors banners at the top of the page is a good place to start for a rebuild kit. Also your local Cub Cadet dealer should be able to get you what you need.
Hellow! Welcome to Only Cub Cadets.net!
A Cub Cadet is for KEEPS! Will last you a life time! Can you afford to keep replacing CHEEP machines? Nice to have you with us!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
