Old 07-25-2011, 05:35 AM
Tool Maker's Avatar
Tool Maker Tool Maker is offline
Default Kohler K361 Questions/Opinions
I recently bout a 1981 Power King 2418 tractor. It has the original kohler k361 engine. I have only had the tractor about a week and only driven it a few times. It does not smoke or use any oil and it is one of the smoothest running small engines I have (no shake at all). I have read lots of horror stories about these engines online. What do you guys think of these engines? Should I run it at half or full throttle? Will some Marvel Mystery Oil in the gas and oil help lube the OHV? I just want to make sure I'm doing my part to make this engine last and I also want your input as well. Thanks in advance.
Cub 126 w/creeper & lift assist, IH wheel weights, Rear Lift, 10" Plow, IH front blade, QA42A Snow Thrower
Cub 149 w/48" mower deck, wheel weights
Old 07-25-2011, 07:31 AM
The Kohler Service Manual recommends always running the K Series motor at full throttle to achieve maximum cooling.
