Old 03-20-2009, 03:01 AM
lonnyb's Avatar
lonnyb lonnyb is offline
Default Cub 582 Special
I recently acquired a 582 special and am in the process of going through it to make sure it is in runnung condition.
The hour meter on this cub only shows 639 hours run time.
When I received it the previous owner said it would not start, I checked the motor and it was over full of oil/gas mix in the crankcase, guess the float stuck and all the gas that was in the tank drained into the motor.
I removed the tin on the motor to inspect the cooling fins for debris and found none. I drained the oil/gas mix out of the motor and fill to correct level with new 10w-30 oil. Drained out the remaining old gas from the tank and added 2 fresh gallons of gas, installed a good battery and turned the key.
After a bit of coaxing it fired up and ran nice and smooth.
I am planning on turning this cub into a snowplowing tractor once I get all the needed parts.
Old 03-20-2009, 05:41 AM
dyt4000's Avatar
dyt4000 dyt4000 is offline
Not being a smart@$$, but why is it called a "special"?
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 03-20-2009, 06:51 AM
David:
It is because it has a "special" transmission. Instead of the traditional IH rear end in it, it has a Peerless Transaxle, run by a belt.
Old 03-20-2009, 06:58 AM
dyt4000's Avatar
David:
Was it considered an "entry level" tractor or something? Hard to imagine a Cub Cadet without the Farmall rearend...
Co-Founder
Old 03-20-2009, 07:48 AM
As I am told, it was developed to compete (in price) with the Hardware Store (MTD branded) tractors.
Old 03-20-2009, 08:48 AM
weaverama weaverama is offline
It would be real interesting to find the original retail price of a 582 Special compared to a 582. I have run across a few Specials for sale over the last couple years, they were tempting, but I resisted. I don't know, it's something about belts and Peerless transaxles. I'm sure they would still outlast any comparable tractor of the same period, and have!
Old 03-20-2009, 09:43 AM
murphycc
Guest
Posts: n/a
http://www.wheatfarm.com/ih_582/index.html
Scroll about 3/4 of the way down and you'll see the tranny.
Scott
Old 03-20-2009, 11:40 AM
young enthusiest's Avatar
So there is some kind of a gearbox that belt-drives the transmission? that seems like a pretty fault-prone design.
Old 03-20-2009, 11:43 AM
Great looking tractor Lonny!
Old 03-20-2009, 11:46 AM
The engine is mounted in the same fashion as it is in all other Cub Cadets, but it drives a right-angle gearbox that drives a belt that drives the rear. The rear is much smaller and lighter than the normal Cub rear, and it's not as strong. It probably works alright for mowing, but any ground-engaging equipment would probably destroy it. I remember being at a plow day once where someone was plowing with one of these and broke it. I also believe that some of the gear drive green tractors had that rear.
