Old 07-30-2011, 09:43 AM
brentwd's Avatar
brentwd brentwd is offline
Default Cylinder head truing
I have a K 301 that I am fixing some oil leaks. I pulled the head off to decarbonize the head. I went to check for straightness on a piece of plate glass and noticed it actually ROCKED on the glass. I have tried to file the head and found it to far gone. I am looking for any ideas people have tried or had done. I have seen some horrors people have posted and wanted some ideas.
Old 07-30-2011, 09:47 AM
jeff194307's Avatar
jeff194307 jeff194307 is offline
Attach some medium grit wet/dry sand paper to you glass with spray adhesive, then using a figure eight motion resurface the head. In time you should be able to get it flat.
JMAC Small Engine
Monmouth Illinois
309-734-0544
Old 07-30-2011, 09:57 AM
jsoluna's Avatar
jsoluna jsoluna is offline
My K301a was exactly the same. Followed a writeup here on how to resurface the cylinder head, and it worked great.
It took quite a while, and I even went with a little more coarse grit than the writeup recommended at first, and then finished it with a fine grit, both were done by wet sand method.
When I started it rocked back and forth on the glass surface horribly, and when I was done I couldn't even get a feeler gauge under it
Ran it at WOT for mowing, let it cool, re-torqued the bolts, and she's been good ever since.
Old 07-30-2011, 10:59 AM
Here it is!
http://www.onlycubcadets.net/forum/s...ead.php?t=5656
