Old 08-01-2011, 09:41 PM
jeffscub's Avatar
jeffscub jeffscub is offline
Default hitch connections
just acquired a hitch today and i am new to the connections. i got the sleeve hitch in the back connected but how does the connecting bar attach at the front? which side?? thanks jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 08-01-2011, 09:53 PM
This should help: http://ccmanuals.info/pdf/WF%203PT%20Install.pdf
Wish I had pictures of that, but I don't...
Old 08-01-2011, 10:14 PM
jeffscub's Avatar
thank you very much!!!! i looked all over for directions, but this being a monday, i didn't find them. thanks again!!! jeff
Jeff
Old 08-01-2011, 10:17 PM
Bookmark this page:
Old 08-01-2011, 10:48 PM
Merk Merk is offline
Here is a view of that set up on my 149:
Old 08-01-2011, 11:34 PM
scleve scleve is offline
I don't remember if the manual says it or not but putting the pin plate on the arm with a carter key before mounting it to the rock shaft helps.
Old 08-02-2011, 07:17 PM
jeffscub's Avatar
thanks everyone!!! I got it on, now I just need to purchase some longer bolts for the bottom brackets. Jeff
Jeff
Old 08-02-2011, 07:58 PM
Are you going to use grade 8 bolts?
Old 08-02-2011, 08:29 PM
Grade 8 is unnecessary for this...Grade 5 is what it came with and will work just fine.
Old 08-02-2011, 09:31 PM
elbertjolley elbertjolley is offline
WoooHOOOO Matt G the man is still around!!!!
