Just as I thought I had all the problems fixed on the 680, something else happened. I was mowing with it and wen I was done I noticed spots on the sidewalk were I had backed up earlier. I couldn't figure out what it was. I finally decided to take the tunnel cover off and found out that the one check valve is spitting out hydro fluid, it's the left one if you're on the seat, only seems to leak in reverse. Is the vavle stuck, bad, or bad o-ring? Thank you, all help is appreciated.
Kris 63 CC Original w/ 38” deck and front plow 72 129 50” deck, 42” blade 73 86 42” deck, 42” blade 84 CC 680 w/50” deck and 42" plow 89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2 1982 Gilson Lawn Tractor with 38" deck
It sounds like the valve has gone bad. Swap the valves and see if it happens in the same side or if it will happen with that valve on the right side. If so it is bad. If the same side, something else might be going on.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Just had the same problem on my 1572. I ordered the valves from L & J fluidpower. I have not put them in yet, They were 57.00 each and 5.00 shipping.
Do you have part numbers for ordering from L & J?
